| B body brakes on early A body? https://slantsix.org/forum/viewtopic.php?t=9964 |
| Author: | ateam [ Thu Jul 29, 2004 7:11 pm ] |
| Post subject: | B body brakes on early A body? |
Can I use 66 B body 10" brakes on a 64 A body? |
| Author: | Matt Cramer [ Sat Aug 07, 2004 10:47 am ] |
Not without some creative machine work. |
| Author: | Mike Andreas [ Wed Aug 11, 2004 10:27 am ] |
| Post subject: | Interesting info at Big Block Dart |
http://www.bigblockdart.com/tech/diskconversion.shtml Mike |
| Author: | andyf [ Thu Sep 02, 2004 11:38 am ] |
wouldn't you just need to change the UCA to get the larger upper ball joint? Then the B body knuckle should bolt right in? Of course, I'd ask why bother. If you're going to change the upper arm then just go ahead and put some disk knuckles on there. |
