It is currently Fri Nov 13, 2026 7:18 pm
Post new topic  Reply to topic  [ 35 posts ]  Go to page 1 2 3 Next
PostPosted: Mon Mar 23, 2009 2:48 pm
This a look at the custom fabercation electrical panel that I mounted under the dash of my 56 Dodge truck. I have recently installed an American Auto Wire harness in my Hot Rod and I wanted to share some pics.
Here is the custom stainless fire wall with the slant six reflecting in it.[/img]
1956 Dodge D100 Pick up
power plant 225 slant six
PostPosted: Thu Mar 26, 2009 5:48 am
That is beautiful old school!
Thanks for sharing!
PostPosted: Thu Mar 26, 2009 7:10 am
COOL
I love the old school look. Keep us posted.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Thu Mar 26, 2009 3:06 pm
Thank you for the nice comments I have alot of fun working on this truck!
PostPosted: Thu Apr 02, 2009 5:19 pm
Whoa, that looks really boss!
I feel the above jargon is appropiate, it is a '56 truck/rod. 8)
I really like it. I have wondered if there are any potential issues with mounting the ECU inside under the dash, it would help keep the engine bay looking clean.
I would think that the ECU and other components would stay cooler under the dash, which I believe is a good thing.
'78 Volare 225
'67 Charger 318
PostPosted: Thu Apr 02, 2009 5:29 pm
I forgot to ask, is it mounted under the driver's side, or the passenger side? Just curious.
'78 Volare 225
'67 Charger 318
PostPosted: Fri Apr 03, 2009 3:39 am
I do not for see any problems with mounting under the dash Hot rodders have been doing it for years to clean up the engine bay. I mounted everything under the passengers side dash because of the room that was available after removing the heater it worked out great! check out some more pics on the gallery section of this site. have a great day and thanks for the interest. Jim
PostPosted: Sun Apr 05, 2009 11:23 am
Looks great! I have a '48 Ferd F-1 that I will be starting soon. I've seen a local guy at car shows selling those wiring kits. Where did you get yours?
Jerry
PostPosted: Sun Apr 05, 2009 7:27 pm
I like the under dash idea. I might have to do that and completely redo all my underdash wiring. Not a bad idea relocating the voltage regulator too. I like it I like it.....
Is that a Painless fusebox you're using? I'd like to find one that has spots for two relays that have power output on something like four fused circuits each.
 Post subject: reply
PostPosted: Mon Apr 06, 2009 3:34 am
Yes it is an American auto wire fuse box they have several options in kits depending on what you are looking for. I Moved everything from the engine bay to under the dash to clean up the engine bay (starter solenoid, voltage regulator, ballast resistor , ecu) the panel I made removes with two nuts and alows for easy access to the componets without crawling under the dash. you can sit on the passenger side floor and work on the panel with ease.
PostPosted: Mon Apr 06, 2009 5:33 am
Car Model: 1967 Dodge Dart GT
yeah, i would imagine that keeping that stuff cooler would be a good thing. it looks good and easy to work on, the ground studs on the top are nice too.
PostPosted: Mon Apr 06, 2009 6:33 am
And..... you got this where? Do they sell directly to the public, or did you get yours from a dealer?
PostPosted: Tue Apr 07, 2009 3:15 am
74 Sport, sorry I missed your first question. I bought the kit directly from www.Americanautowire.com I went with the power plus 20 series with power seats windows and locks for future instalations.
PostPosted: Tue Apr 07, 2009 7:21 am
Hey, no problem. As I said, there is a guy making all the local car shows selling that same kit for $450. I'll check with them to see what it really costs. He sure talks it up to be a fantastic product - likes it much better than Painless (he also sells their stuff).
PostPosted: Thu Apr 09, 2009 6:54 am
Oh man they need a new site. That site's gnarly (and not in a good way) :shock:
Looks like good products at least, though.
