It is currently Sun Nov 08, 2026 9:45 pm
Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 1 post ]
PostPosted: Tue Dec 29, 2009 3:10 pm
Site Admin
Learn from the mistakes of others. You won't live long enough to make all of them yourself. - Unknown
TRICKS to using the Search Feature
Red text is a link. left click on the text, and you will go to the information described.
Check the Articles section from the Home page first!
Here's a quick link to help you get there:
Tech Articles
Links
ARP Head Stud Instructions
Autometer tach 1
Autometer tach 2
Manifold Studs Price is each
Technical Threads:
Band Sawed Slant 6 Head
Band Sawed Slant 6 Head Water Jacket
Bearing Failure Guide
Best of Doctor Dodge
Cam info, Hydraulic vs Mechanical
Cam info, Erson
Erson Legacy Cam Info
Cam specs; Dutra RV10 RV15 RDP
Cam specs; OCG Hydaulic
Legacy Cam specs; OCG Mechanical
Cam specs; OCG Mechanical updated 2015-03-21
Cam Specs; OCG Mechanical Roller
Cam cards User submitted.
318 Carter BBD and Holley 2280 to SuperSix choke
Carburetor operation & repair information
Carb Plate, Build your own!
Carburetor, parallel two barrel
Carburetor, Weber
Carter BBD for the Super Six, Chrysler Training Video
Carter carb manuals with jet and metering rod sizes
Carter Jet Sizes
Carter Fuel pump kits
Degreeing a cam
Distributor Recurve
Distributor Vacuum Advance Can List
Electronic ignition thoughts.
Emission Controls; The low down.
Engine Block Oiling System Prep
Engine Build Matrix
Fuel Line Mod Improves Starting & Driveability
Head Flow info
Hydraulic Lifter Preload
Kickdown thread
Mini-Starter and More Mini-Starter
And still more mini-starter
Oil Pan Installation
Oil Pans Link
Slant Six Training Video
Timing Curve/Recurve information
Trans & Engine Mounts
Turbo Charging the Slant Six
Valve Adjustment procedure
Dan's links
Miscellaneous:
Automotive Calculators
The Great Carburetor Rebuild Survey
Electrical FAQ-More Ignition information
Piston Motion Basics
Group buys:
ARP Group Buy
CP Pistons
Erson cam group buy Group buy prices no longer in effect.
K1 Wiseco rods and pistons
Poly Engine Mounts for 62-66 cars Group buy prices no longer in effect.
Poly engine mounts for '73+ (spool)! Group buy prices no longer in effect.
Manuals:
Factory Service Manuals
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 4 guests
