It is currently Thu Apr 17, 2025 5:58 pm
Post new topic  Reply to topic  [ 73 posts ]  Go to page 1 2 3 4 5 Next
 Post subject: OHC Slant Six
PostPosted: Wed Jul 17, 2013 1:35 pm
I was an engineer at Chrysler from 1967 – 1971. I designed an OHC slant six while I was at Chrysler and I built it as a 170 cu in version in 1971 - 1972. I installed the engine in a Dart and drove it for about 500 miles. I wanted to use the engine as an example of OHC conversion so I could convince someone to help me create an OHC conversion for the 392 HEMI. I was unable to find interest for this project so I sold the car in 1973.
In 1992, a friend of mine saw my engine at the MSU engine laboratory. I purchased the engine from MSU and it has been stored in garages ever since.
I originally was going to rebuild the engine and install it in a Dart. However, I am now thinking that I really don’t need another car. So, I would like to sell the engine.
Do you have any idea of who might be interested in purchasing this engine?
PostPosted: Wed Jul 17, 2013 1:36 pm
Car Model: 1964 Valiant V200
PM Doug Dutra (Doc) on this forum.
Do you have any pictures? Many of us who are not necessarily interested in buying it would love to see what it looks like.
PostPosted: Wed Jul 17, 2013 1:42 pm
I am new to this site. Is there a way to post pics on the site? If not, I can email pics to you if you give me your email address.
PostPosted: Wed Jul 17, 2013 1:44 pm
I know a number of members would be VERY interested in any details you could provide about the conversion process and how it was achieved. Pictures, diagrams, tech papers, discussion, etc... would be greatly appreciated.
You can e-mail me any pictures you would like posted and I will post them for you. My direct e-mail is reedspeirlaw at seanet dot com Remove the spaces and replace the "at" and "dot".
PostPosted: Wed Jul 17, 2013 2:08 pm
jimgrundy,
I second that ! ......email ....tedschultz74@Hotmail.com
please send pictures and info and we will get it posted.
 Post subject: This is SO cool!
PostPosted: Wed Jul 17, 2013 2:17 pm
Here are the pictures and info I have received from Mr. Grundy. This is pretty dang cool in my book.
Subject: Slant Six - Day 1 of disassembly
Began taking engine apart:
* There were 2 gaskets under plexiglas cover and bottom one will need to be replaced.
* Valve gear looked good with no wear and only superficial marks on some of the rollers.
* MSU must have removed intake and exhausts because there were only three bolts holding them on - there are a lot of studs missing from the head. Also, I think there is at least one bracket that was supposed to go from intake to block that is missing. Also, there were no gaskets between intake/exhausts and head.
* The clutch plate and the flywheel have no wear - buyer must not have driven much.
* Timing belt appears ok but I would worry about age.
* Missing starter.
* Missing arm and throw out bearing for clutch actuation.
 Post subject: More coolness
PostPosted: Wed Jul 17, 2013 2:18 pm
Subject: Slant Six - day 2 of disassembly
* removed back pulley on camshaft
* removed all rocker arms
* removed rocker shaft
* will need external retaining ring pillars to remove tru-arc ring on cam
 Post subject: Yet more coolness
PostPosted: Wed Jul 17, 2013 2:29 pm
Subject: Day 3 of disassembly
Removed cam thrust bearing assembly. Order for pieces starting at #1 bracket and then moving forward:
* Washer with 4 scallops on inside diameter
* Needle bearing washer
* Washer
* Two 1/2 washers with large diameter facing to rear
* Tru-Arc snap ring
Removed cam and brackets.
I asked Mr. Grundy what cam was used and if he remembers any of the other parts that were used and here is his response:
"I looked in my old files and unfortunately, I didn't record the PN [for the cam]. I think it was either the timing belt from the Pontiac OHC six or it was a Uniroyal timing belt. The tensioner was from a Pinto engine. The rocker arms were my design and the rollers were from the Ford 427 SOHC engine."
Look close to see the Hyperpak manifolds!
PostPosted: Wed Jul 17, 2013 2:41 pm
Poser
Well I'll be dipped in shyt! :shock: :shock: :shock:
PostPosted: Wed Jul 17, 2013 3:42 pm
A cam drive from the back, what a neat idea!
PostPosted: Wed Jul 17, 2013 3:45 pm
What does the belt drive off the crank look like? Is it a cogged hub bolted to the crank flange? And then the flywheel bolted to the cogged hub?
PostPosted: Wed Jul 17, 2013 3:48 pm
I suspect it is a cog bolted to the back of the crank that doubles as the spacer to the clutch, like the spacer in the old slant to smallblock adapter system on the mid 60s A series vans and trucks.
PostPosted: Wed Jul 17, 2013 4:03 pm
Jimgrundy, I guess our collective awe made us forget: Welcome to the forum!
I doubt if any first posts ever have blown so many people off their chairs as your did!
Absolutely awsome material!
Olaf
Aspenized
PostPosted: Wed Jul 17, 2013 4:07 pm
man that is pretty cool, and really doesn't look to hard to make yourself I would say, just a crap ton of machining lol, and that rear mount cam drive, pretty genius setup !!!
I am the Guardian, I hate helos, everything leaks.......
PostPosted: Wed Jul 17, 2013 4:37 pm
Was the stock cam and timing setup left in place to drive the oil pump and distributor?
Users browsing this forum: Semrush [Bot] and 2 guests
