It is currently Sun Jun 21, 2026 3:58 am
PostPosted: Sun Apr 02, 2006 5:34 pm
While I was taking my BBD apart to rebuild it, I found a pair of plastic pieces sitting in the bottom if the pump housing, I didn't understand the purpose of these parts until I started putting the carb back together:
They are the two arms tha actuate the metering rods. Can I get this part replaced? Or am I stuck with a half rebuilt carb I can't use?
Thanks
70 Dart, 360, 727
PostPosted: Sun Apr 02, 2006 7:08 pm
You could try a product like Goriolla Glue, but your best bet is to nab a new plastic tab piece from a boneyard BBD.
PostPosted: Mon Apr 03, 2006 11:38 pm
I'm gonna try and fab something up, hopefully what I have in mind will work.
70 Dart, 360, 727
PostPosted: Thu Apr 06, 2006 3:15 pm
Tried the Gorilla glue, wow! That stuff is tough! It's holding as of right now, we'll see how it goes, I may need to replace the carb anyhow, it's leaking a lot, and the shafts seem to have a lot play.
70 Dart, 360, 727
PostPosted: Thu Apr 06, 2006 3:35 pm
Lars- if you end up replacing the carb I would be interested in purchasing your old one.
Those plastic tabs are a very low stress piece so the gorilla glue should work fine (as long as the gas fumes don't dissolve it).
PostPosted: Thu Apr 06, 2006 5:19 pm
I'll let you know, I may not have gotten it clean enough. I've never had good luck with Carter's, Holley's have always been better to me, course fuel injection has always treated me the best. :P
70 Dart, 360, 727
PostPosted: Thu Apr 06, 2006 7:05 pm
Interesting, I have had exactly the opposite luck!
PostPosted: Thu Apr 06, 2006 7:51 pm
LOL! I'm gonna hit up one of my favorite junkyards this weekend and see if they have any Holleys, maybe I'll get lucky.
70 Dart, 360, 727
PostPosted: Thu Apr 06, 2006 8:12 pm
I have a Holley/Motorcraft 2-barrel (2300?) off of a Ford 302. Sell it to ya' cheap if the carter doesn't work out or you can't find any other Holleys. Needs a rebuild and is greasy but other than that it is fine.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Fri Apr 07, 2006 11:49 pm
Will the kickdown linkage fit since it's off a Ford? I'm hitting the yard today, hopefully I'll get lucky.
70 Dart, 360, 727
PostPosted: Sat Apr 08, 2006 4:14 am
No, you will have to do some engineering to get the kickdown to fit or fab a new one.
82 D150-225/727
PostPosted: Sat Apr 08, 2006 10:21 am
Well, no Holleys, but I scored another BBD for $15. It looks cleaner then the one I've got, I'ma give it a shot and see if it runs any better. If not they'll be up for sale on here for you guys.
70 Dart, 360, 727
