It is currently Fri Jan 30, 2026 7:58 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 7 posts ]
 Post subject: Cam blank shortage?
PostPosted: Tue Jul 31, 2001 7:00 pm
I called Clifford Performance today to check on a cam that I ordered four weeks ago, and they havent even made it yet! They said that they are out of blanks and they did not know when they would be getting any because there is only one company in the USA that makes them and they are going out of business. Are they pulling my leg or what? I need a BIG cam soon! Something for a 198/2.2/hyperpac with high compression and high stall converter. THANKS! Darrin
dartman225@webtv.net
 Post subject: Re: Cam blank shortage?
PostPosted: Tue Jul 31, 2001 9:46 pm
: I called Clifford Performance today to check on
: a cam that I ordered four weeks ago, and
: they havent even made it yet! They said that
: they are out of blanks and they did not know
: when they would be getting any because there
: is only one company in the USA that makes
: them and they are going out of business. Are
: they pulling my leg or what? I need a BIG
: cam soon! Something for a 198/2.2/hyperpac
: with high compression and high stall
: converter. THANKS! Darrin
I was just over at Clay Smith cams last week to see about getting a turbo grind for my 225 and seemed to be no problem BUT I haven't picked it up yet....... WE'LL SEE
mopar.mopar@gte.com
PostPosted: Wed Aug 01, 2001 2:45 am
i just ordered mine through reed cams. good people to deal with (so far, not installed yet, looks to be a nice piece) check out reedcams.com give rick a call. he can help you out. mine was ordered last tuesday, and here this past monday. they like to do custom grinds. and will work with you to suit your needs.....chad
beardliz@msn.com
 Post subject: Re: Turbo Cam
PostPosted: Wed Aug 01, 2001 8:27 pm
: I was just over at Clay Smith cams last week to
: see about getting a turbo grind for my 225
: and seemed to be no problem BUT I haven't
: picked it up yet....... WE'LL SEE
Could you post some info on what grind you're getting made for your turbo application? I'm sure that lots of people would be interested to see it.
Dan
dan.k@pakistanmail.com
PostPosted: Thu Aug 02, 2001 12:44 am
: Could you post some info on what grind you're
: getting made for your turbo application? I'm
: sure that lots of people would be interested
: to see it.
: Dan
Hi Dan
I sure will don't have the spec's yet only that it will be around 280 degrees I have to take them some more info on the motor should have all the info next week
PostPosted: Fri Aug 03, 2001 8:23 pm
Sounds to me like "Uncle Jack" doesn't want to screw around with us "frugal" Slanters anymore.
aschumers@aol.com
PostPosted: Fri Aug 03, 2001 8:37 pm
: Sounds to me like "Uncle Jack"
: doesn't want to screw around with us
: "frugal" Slanters anymore.
I agree. I just wish that they would have told me that a month ago! I will try to call Reedcams on Monday and see if they can hook me up with something.
