It is currently Mon Oct 12, 2026 9:34 pm
Post new topic  Reply to topic  [ 40 posts ]  Go to page Previous 1 2 3 Next
 Post subject: Finally
PostPosted: Tue Apr 11, 2006 5:49 am
Well I finally got to opening up the other 1920 that was giving me trouble.
And this is what I saw:
Is the spring supposed to look like that? I've never done this before so I just don't know.
I've taken a bunch of other pictures, so if you see something you need to see more of, let me know and I'll pop it up here.
And thanks to all for your help.
The old white brick
PostPosted: Tue Apr 11, 2006 7:46 am
There's a tiny hole in the stainless-steel float arm, into which the spring's top spike is supposed to fit. From that photo, it looks as if your spring might not be quite properly placed.
PostPosted: Tue Apr 11, 2006 7:50 am
took it out, here it is from the backside.
The old white brick
PostPosted: Tue Apr 11, 2006 7:51 am
Other than that, when I go in to ask for a rebuild kit, do I simply tell them the year and make of the car and the engine, or do i need a number off of the carb itself?
The old white brick
PostPosted: Tue Apr 11, 2006 8:19 am
It helps to have the carb number. There are all sort of discrepencies in carb models, such as high altitude setups, Cleaner Air Package, and all sorts of weird things. I always like to come prepared with as much information as possible.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Tue Apr 11, 2006 8:20 am
'Kay, what does a carb number look like and where on the body of the carb I am looking for one?
The old white brick
PostPosted: Tue Apr 11, 2006 8:32 am
OK, your float counterspring is installed correctly. The carb number is stamped on the carb near the top-right-front area, and looks like "R7584S" or "R3887SA" (these are example numbers). Couldn't hurt to get a new float, too!
 Post subject: Try this kit.
PostPosted: Tue Apr 11, 2006 9:09 am
So far the only quality kit I've found in town is the Borg-Warner Kit # 10392A...This will cover all Holley 1920 models from 1966-1973.
PostPosted: Tue Apr 11, 2006 9:18 am
Good to know, thanks DI. And I'm still looking for that durned number. All I've found so far are a couple of numbers like 12r-4325b. Things like that.
The old white brick
PostPosted: Tue Apr 11, 2006 10:22 am
Could well be it—where on the carb is it?
PostPosted: Tue Apr 11, 2006 11:17 am
I think that was the number from the carb I replaced this one with.
But you can see where it is in the picture.
The old white brick
PostPosted: Tue Apr 11, 2006 12:14 pm
Naw, that's a casting number. Look on the top and front surfaces of the part of the casting indicated by the green arrows:
PostPosted: Tue Apr 11, 2006 12:31 pm
These are the only numbers up there, I'm going to get some berryman's cleaner and soak this puppy and see if any numbers turn up under the grease. This is one that i found just from a little cleaning this afternoon.
Says 1722
6156
The old white brick
PostPosted: Wed Apr 12, 2006 8:10 am
Still no numbers visible. its soaking in B12 at the moment since the parts store didn't have the B9 schtuff. Will this clean it adequately?
The old white brick
PostPosted: Wed Apr 12, 2006 9:28 am
The carb number you are looking for is the "list" number. This is found on a little stamped aluminium tab which is held in place by one of the float bowl screws. Yours appears to be missing. The other numbers are casting numbers and won't correspond to a carb rebuild kit.
Any decent carb rebuild kit will be generic and contain a number of different gaskets for the slight variation amongst carb models. Just be careful in selecting which gaskets to use and you will be fine.
Users browsing this forum: DuckDuckGo [Bot] and 15 guests
