It is currently Wed May 27, 2026 1:05 pm
 Post subject: Moly rings
PostPosted: Thu Aug 02, 2001 4:25 am
67'Dart. Did any years have Moly rings? I doing a body resto this winter, and will have the engine
out. It has 85K , run's great (except for mileage) and I was thinking of a ring job
using moly's to buy some bore life, or do you think the ridge has already formed? Thanks
 Post subject: Re: Moly rings
PostPosted: Thu Aug 02, 2001 9:29 am
: 67'Dart. Did any years have Moly rings? I doing
: a body resto this winter, and will have the
: engine
: out. It has 85K , run's great (except for
: mileage) and I was thinking of a ring job
: using moly's to buy some bore life, or do you
: think the ridge has already formed? Thanks
i would not put moly rings in 85,000 mile bores. they are tapered and out of round by now, and the ridge has almost definately formed. try a ridge reamer, ball hone, and a set of cast rings. they will seal much better than the molys. moly in a fresh bore is another story.
beardliz@msn.com
