It is currently Wed Jun 10, 2026 4:00 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
 Post subject: shakes while cold
PostPosted: Thu Aug 02, 2001 2:33 pm
This problem just started recently. When the engine is cold it has no power and shakes like it's missing. However once it warms up everything is perfectly fine.
snarl@net-change.com
 Post subject: Re: shakes while cold
PostPosted: Thu Aug 02, 2001 7:25 pm
My '64 does the same thing, and it's caused by fouled plugs that clear after the engine gets hot.
PostPosted: Thu Aug 02, 2001 10:15 pm
: My '64 does the same thing, and it's caused by
: fouled plugs that clear after the engine
: gets hot.
Try this....
When cold,... pull-off the air cleaner before you start the car. "Pump" the throttle once by hand to make sure the choke fully closes. (it should just snap-shut)
Now start the car and look to see if the choke "pull-off" (vacuum diaphram) pulls the choke flap about 1/3 open. Try *slowly* opening the choke flap more to see if the engine runs better with additional air.
Adjust the "dogleg" pull-off linkage or replace the vacuum "pod" as needed. (they do ware-out)
If the engine runs very long on a closed choke, it will "soot foul" the spark plugs.
PostPosted: Mon Dec 17, 2001 11:16 am
My '81 van did the same thing ( much worse in winter) and I had little luck with professional shops in identifying a completely dead pull-off. I guess they mainly understand fuel injection nowadays.
in : My '64 does the same thing, and it's caused by
: gets hot.
darelohs@islandnet.com
