It is currently Wed Dec 31, 2025 4:23 am
PostPosted: Wed Apr 12, 2006 6:49 pm
if you do the numbers, a none boosted 225 at sea level with 100% efficiency (reality, the max would be 85%) would have a max CFM of 326 at 5000 rpm. as you increase altitude, it drops. so at 500 feet and at 85% its only 277 CFM so with this you can decide how much carb you need...just thought i would pass this on GRT ps thats why webers are so good for these engines..I used to sell and install webers and they perform very close to the same as a throttle body...pss a 38 dgv weber is 390cfm approximate :shock:
PostPosted: Thu Apr 13, 2006 9:31 am
What Weber carb will fit the /6 two barrel intake, and what were they used on?
70 Valiant Super Six
PostPosted: Thu Apr 13, 2006 9:39 am
None. All will require an adapter.
The Holley 5200 flows 280 CFM.
PostPosted: Thu Apr 13, 2006 9:46 am
I was very happy with the 38-38 weber , but the linkages was no fun
PostPosted: Thu Apr 13, 2006 5:26 pm
99004.551 weber adapter kit....most are $35 to $45 depending on where you get it GRT
PostPosted: Fri Apr 14, 2006 10:54 am
These are the ones I know about.
I tracked my 5210 down to coming off of a 1977 Vega. I found this info out of a Chilton Auto Repair Manual 1975 through 1982.
The 5200 is considerd a Ford Autolite Motorcraft Carb.(at least in this manual). From 1975-1981.
The 5210 is considerd a Holley as is the rest of the numbers below.
The 5210 included AMC 1977-1979.
GMC Chevette 1979 and 1980, Monza & Vega 1975-1978, Starfire 1976-1978, Astre, Sunbird and Ventura 1975-1978.
Numbers below are more electronic.
The 5220 is a 1978-1981 Chrysler Omni/Horizon version.
The 6500 is a 1978-1981 Ford Pinto/Bobcat.
The 6510 is a 1978-1981 GMC.
The 6145 and 6520 is a 1981 Chrysler.
82 D150 Slant6 Shorty
http://www.cardomain.com/ride/658846
PostPosted: Fri Apr 14, 2006 12:53 pm
My '84 Dodge Shelby Charger came with a Holley 6510 carburetor.
PostPosted: Fri Apr 14, 2006 1:43 pm
5220 and 6520 (O2 feedback) and both vacuum secondary found on caravans up to mid 1987.
Cheers, Wizard
PostPosted: Fri Apr 14, 2006 6:41 pm
How much does a BBD flow?
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Sat Apr 15, 2006 3:28 am
I have seen them listed as 280 or so cfm...
PostPosted: Sat Apr 15, 2006 9:12 am
Yeah. A BBD is rated at 280 CFM, except the BBDs that were installed on 383 motors.
PostPosted: Sat Apr 15, 2006 1:48 pm
Don't forget that 1 BBL & 2 BBL carbs use the 3.0 inHg method to rate air flow CFM and 4 BBL carbs use the 1.5 inHg method........
Here's the formula
(4bbl rating) = ((2bbl rating)/1.414)
(2bbl rating) = ((4bbl rating)*1.414)
Users browsing this forum: Amazon [Bot], Google [Bot] and 2 guests
