It is currently Wed Oct 07, 2026 4:22 pm
 Post subject: Valve angle question
PostPosted: Fri Apr 14, 2006 1:05 am
Car Model: Valiant V200 225 4dr three on the tree
Has there been any changes in valve angles, depending of the year of the engine?
Lasse
Signet -66 225
Holley 600 Offy-5270 Dutra Dual,regrind. cam 272 0,420 110, head shaved 0.100 slight.ported
MSD6A
A904
7 1/4 3.23
PostPosted: Fri Apr 14, 2006 7:40 am
No.
PostPosted: Fri Apr 14, 2006 10:51 am
Then when I got a head with 2 exhaustvalves that got 50 degr. Somebody have done a bad valvejob. The rest is 45 degr.
Lasse
Signet -66 225
MSD6A
A904
7 1/4 3.23
PostPosted: Fri Apr 14, 2006 11:25 am
Yep, sounds like someone was too far into the Aquavit when doing that valve job :-)
 Post subject: Vj
PostPosted: Fri Apr 14, 2006 11:40 am
You can grind the seats and valve faces to anything you want (within reason). Some people cut the valve face at 44, and the seats at 30/45/60 where the 45 is the area being hit by the valve. Some people cut the valve face at 2 angles (back-cut) and the seat at 5 angles. It varies, depending on the builder.
But for most stock applications, it's a 45 on both. A mismatched angle on the same head is a mistake. (slipped adjuster on valve machine OR more likely, a very worn 45 stone...are the 50's on one end of the head?)
PostPosted: Sat Apr 15, 2006 12:08 am
They are on cyl 3 and 4, these valves have been changed at some time, they are the "early" type with 3 (or 4) groves, all the others got 2.
Lasse
Signet -66 225
MSD6A
A904
7 1/4 3.23
 Post subject: valves
PostPosted: Sat Apr 15, 2006 9:56 am
Seems like the two were done as a "fix" to the head and not a complete valve job. As long as the seat and valve face match, it'll work, but I'd say get them all re-cut to match.
Users browsing this forum: No registered users and 17 guests
