It is currently Tue Nov 24, 2026 5:05 pm
 Post subject: 2 bbl. kickdown/headers?
PostPosted: Sun Apr 16, 2006 8:25 pm
if i put on headers then i have no place to put my kickdown bracket since it normally bolts to the bottom of the exhaust manifold. so then should i just bolt it to the intake and make some spacers that will lower it down or is there enough adjustment to bolt it flat on the bottom of the intake? im not going to swap it untill schools out cause it is my daily driver but i just want to have everthing all ready when summer comes
chris
1975 Plymouth Duster,225/6 2bbl. and duels, 904, 7 1/4
1986 Dodge Charger Shelby, 2.2 Turbo I, A525
PostPosted: Sun Apr 16, 2006 8:38 pm
Yep! That's exactly how to do it. You can even use stacked washers, if it comes to that.
PostPosted: Sun Apr 16, 2006 9:20 pm
thank you
chris
Users browsing this forum: DuckDuckGo [Bot] and 8 guests
