It is currently Mon Nov 23, 2026 6:48 pm
PostPosted: Tue Apr 18, 2006 8:12 pm
that's all...
I have the chance of getting a reasonably priced comp 264S kit (cam, springs, timing set, lifters) and I just wanted to hear opinions from people using this cam.
Juan Ignacio Caino
PostPosted: Tue Apr 18, 2006 8:26 pm
I have a 264s in the Valaint. Its ,,,,,well....ok.
I have big valves and 9.25 CR and would prolly get a bigger cam if a free comp 264s had not come my way.
Its,,,,well....ok I guess......
PostPosted: Tue Apr 18, 2006 9:29 pm
Car Model: 1962 Lancer 770
Now that's a ringing endorsement Sandy ;) I'd be interested in what you don't like about it.
MJ
PostPosted: Wed Apr 19, 2006 4:49 am
well.... now you got me wondering. I have a mild-street slant with a 904 behind. what you LIKE and what you DONT LIKE about it.
Juan Ignacio Caino
PostPosted: Wed Apr 19, 2006 8:09 am
Si. I, like S/BC, run the 264S and wish I had more cam. I was concerned about idle quality with the A/C but I now realize I could've gotten away with a bunch more.
Upside: Everyone will think your cam is stock, but you will have more mid-range power.
Downside: Nobody will notice you cammed your ride, idle is smooth as silk. You'll be just like me and S/BC and wish you had more cam, for power and for rumpety idle note.
D/W
If it ain't broke, fix it!
PostPosted: Wed Apr 19, 2006 9:03 am
Thanks Dennis.
 Post subject: Yup...
PostPosted: Wed Apr 19, 2006 9:53 am
I concur, I also will add that I notice the cam has a tendency to 'come on' a bit later than the 252 I have in the Hpak duster (like Dennis said it's better in the 'mid-range' not a low end torque-stick).
PostPosted: Wed Apr 19, 2006 2:09 pm
anyone have an opinion on comp cams lifters?
I have heard many people bad mouth that company on this board.......well........one in particular.... :)
PostPosted: Wed Apr 19, 2006 7:25 pm
Although I have 4 vehicles with Comp Cams ,,,,all use stock lifters....which I recommend (Chev and Chryco)
PostPosted: Thu Apr 20, 2006 2:01 pm
I ask because I need a new set, and they seem to be the only "name" manufacturer I can find in my PAW catalog. PAW makes a generic set too, just can't find anyone that used them. I put a bucket of cash into this biuld and don't want to risk anything.
PostPosted: Thu Apr 20, 2006 2:30 pm
Just to tag on to what D.Idiot says about the 264. The 252 comes on a little latter than the stock 244. The stock cam has more low end torque than the 252.
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Thu Apr 20, 2006 9:13 pm
so a 264 will sound like stock but give extra performance.... I like that.
I was trying to make up my mind between comp 264S or erson 270º cam. (listed on summit)
I have a set of brand new stock lifters.... do they need to be worked in any way to run with any of those "hopped up" cam profiles?
last question (promisse) does anyone has experienced premature wear oand/or gear chewing with comp 264S like the (bad) reputation that the 252S has?
Juan Ignacio Caino
PostPosted: Fri Apr 21, 2006 6:41 am
Mine chomped a gear in 2 weeks....rebuilt pump. I changed the pump out to a used stock pump...N/P since.
I would get the Erson cam.
 Post subject: Hmmm...
PostPosted: Fri Apr 21, 2006 9:24 am
My 252S is still going strong after 36000 miles, of course I bought the Comp Cam and Lifter set back in 2000 when I rebuilt the motor too...
Part of the reason the 252 feels less torquey than the 244 is the cam lobe separation for Comp Cam is almost always 110 deg. and the stock cam was 108...if they ground the 252 for a 108/109 you'd have that torque back (but then again the torque curve is already pretty flat with most grunt motors anyway...)
PostPosted: Fri Apr 21, 2006 5:14 pm
Car Model: 1964 Dart GT
I have that cam in my 64 Dart with a 4 speed, big valves, Offy intake w/ a 390 Holley that has been drastically tuned, Dual exhaust, 3.23:1 gears. Like they all said, alot of mid torque but not much below 2500rpm's. With a high stall converter it would be nice, but at that point you might as well get something more radical. My humble opinion. I am installing a Paxton w ~8 lbs. of boost. I will try tit with this cam but I will most likely change it out.
Users browsing this forum: Bing [Bot], Google [Bot] and 7 guests
