It is currently Wed Nov 25, 2026 7:03 am
 Post subject: Mopar Carter AFB's
PostPosted: Wed Apr 19, 2006 6:08 am
I would like to know if there were any Carter AFB's made in the 400CFM range that have Mopar throttle linkages and if so would you have the listing numbers for the carburetor. I would like to do a conversion on my Slant and would rather keep a Mopar setup if possible. I've queried several search engines on the internet and have not have any luck finding a number, any help will be appreciated.
PostPosted: Wed Apr 19, 2006 8:02 am
Yes. I posted a list somewhere a long time ago. I run a 4294S on my Duster. @ approx. 400 CFM, 273 4-speed is the original application for it.
http://www.slantsix.org/forum/viewtopic.php?t=6807
D/W
If it ain't broke, fix it!
PostPosted: Wed Apr 19, 2006 8:33 am
[quote="Dennis Weaver"]Yes. I posted a list somewhere a long time ago. I run a 4294S on my Duster. @ approx. 400 CFM, 273 4-speed is the original application for it.
Thanks for the link and do you like your setup?
PostPosted: Wed Apr 19, 2006 2:45 pm
Wouldn't have kept it like that for so many years if I didn't! I went against my better judgement when I first decided to go from 2 to 4 barrels; I tried the 390 holley thing for a while, that was a constant headache. Driveability, tunability and raw performance were all improved by going to the AFB.
D/W
PostPosted: Wed Apr 19, 2006 5:38 pm
AFB carbs used on 273s.
3853S
3854S
4119S
4120S
4121S
4122S
4295S
There was also AFBs used on poly 318s that may be 400cfm.
3247S
3249S
Slant Cecil
PostPosted: Thu Apr 20, 2006 7:54 am
Thanks for the infos, I too tend to lean towards the AFB for an everyday driver.
