It is currently Fri May 08, 2026 10:47 am
PostPosted: Sat Apr 22, 2006 7:47 pm
What would be the best upgrade for a 64 valiant? bigger drums? full disc conversion? or disc/drum. I cant decide if I should stay old school with the drums or give in to disc performance.
64' Valiant Signet 5.9, 64' Dart 170 moredoor 3.7, 67' A100 3.7, 00' Dakota SLT 4.7
PostPosted: Sat Apr 22, 2006 9:09 pm
What's your plan for the car? Cruiser? Daily driver/commuter? Show car? Drag car? Road racer? Each one can have a different brake system.
I put late-A body manual disks on the front of my '64, and like them very much. When I do something about the small bolt rear end, there will be better brakes there, probably in the form of larger drums.
I did the brake swap because I drive the car to work, on errands all around town, and on the occasional road trip. I want more than "adequate" braking should I ever need it.
I do want to try autocrossing, even if the modfications put me in a much tougher class. I'll be there for fun!
PostPosted: Sat Apr 22, 2006 9:41 pm
this car will be for cruising/errands. I have no problems with the stock brakes, but as you put it. I would like to have more then adequate braking in case I ever need it. their will be no racing for this car. but I dont mind having racing performance in that area.
 Post subject: Valiant
PostPosted: Sat Apr 22, 2006 11:04 pm
DO you have 10 or 9 inch drums on the front?
I found a front set from a donor 69 dart, with 10 inch front drums...bolted right on..made a HUGE difference in braking..maybe my 9s were really worn...then I updated the rears to 10 inch drums
It really depends on how much you wanna spend
After I put the 10 inch drums on the front, I could drive the car all zippy around town with no worries...I also have a 318 in the car :)
65 valiant
PostPosted: Sun Apr 23, 2006 7:18 am
will any drums off an A body fit? I'd like to stay with the drums. What are my size options for bolt in replacements?
PostPosted: Mon Apr 24, 2006 9:38 am
At the very least, upgrade to a dual master cylinder. It costs less than $40 at rockauto.com and takes one afternoon. http://www.earlycuda.org/tech/dualmaster.htm shows the procedure. Id you drive mildly, the stock 9" drums are OK, even for a daily driver.
PostPosted: Mon Apr 24, 2006 10:11 am
the dual MC sounds like the way to go. I love the detailed article. I'll have to call up my parts store and get one.
PostPosted: Mon May 08, 2006 12:36 pm
I rebuilt the brakes in my '64 Valiant convertible a few years ago, all-stock. (The only "old" components are the brake pedal and the backing plates; EVERYTHING else was replaced: wheel & master cyls, lines, flex-hoses, steel tubing, shoes, hardware, drums.)
I'm pretty sure it has 9" drums (six-cylinder).
For a car with Drum brakes, I think they are excellent. I could put passengers over the windshield header if I wanted to.
I'm not saying that the brakes are exempt from the usual drum-brake shortcomings (fade), but my car is a driver, and I find the stock manual drums "more than adequate". My car has 175-70 R 13 tires.
Can't argue about the sense of switching to a dual-reservoir system.
For an around-town driver, the stock brakes are more than sufficient, in my opinion. I have managed to lock the wheels up on mine once or twice.
(None of my older MoPars with Lockheed brakes would ever do that...)
Good luck...
Frank McMullen
Users browsing this forum: Bing [Bot] and 8 guests
