It is currently Tue Nov 17, 2026 5:47 pm
PostPosted: Wed Apr 26, 2006 1:15 pm
I have a 63 dart with the pushbutton tranny - What tranny is it - the 727 or the A 904 (or is it something else)? I want to get the right kickdown linkage when I get my 2-bbl carb.
PostPosted: Wed Apr 26, 2006 1:17 pm
It most likely is the 904. The transmission won't matter with the kickdown linkage. Your difficulty will be in overcoming the rod style throttle linkage.
PostPosted: Wed Apr 26, 2006 1:25 pm
I wonder if I could leave the kickdown linkage the way it is and hook up a universal cable to the pedal or something. . .
PostPosted: Wed Apr 26, 2006 5:07 pm
Look at how the gas pedal actually operates the throttle. There isn't any easy way to retain just 1 piece of the factory setup. The easy way is a floating pedal from a later car and the lokar kd linkage.
Users browsing this forum: Amazon [Bot] and 1 guest
