It is currently Mon May 11, 2026 9:16 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
 Post subject: 78 225 Super Six
PostPosted: Mon Aug 13, 2001 11:49 am
I have a 78 225 Super Six long block out of a Volare. I want to know how do I wire in the electric choke into my 68 Dart's wiring and if I only need to hook-up my vacum advance PCV valve hoses to the 2-barrel or is there any additional hoses that need to be used for it to run right. I took everything that was connected to the engine;wiring,sensors,you name it. Also, would it be easy to wire in the Volare's larger alternater into my Dart?
drucker@sbcglobal.net
PostPosted: Mon Aug 13, 2001 8:46 pm
: I have a 78 225 Super Six long block out of a
: Volare. I want to know how do I wire in the
: electric choke into my 68 Dart's wiring and
: if I only need to hook-up my vacum advance
: PCV valve hoses to the 2-barrel or is there
: any additional hoses that need to be used
: for it to run right. I took everything that
: was connected to the
: engine;wiring,sensors,you name it. Also,
: would it be easy to wire in the Volare's
: larger alternater into my Dart?
The choke resistor wires into the ignition switch "run" circuit *before* it goes into / through the ballist resistor.
As for all the extra carb. vacuum lines, just start with the v. advance and PCV and plug the rest, except the float bowl vent, leave that one open.
PostPosted: Mon Aug 13, 2001 11:17 pm
: The choke resistor wires into the ignition
: switch "run" circuit *before* it
: goes into / through the ballist resistor.
: As for all the extra carb. vacuum lines, just
: start with the v. advance and PCV and plug
: the rest, except the float bowl vent, leave
: that one open.
: DD
Finally an aswer to my question. Thank You Doctor Dodge!
