It is currently Wed May 13, 2026 10:21 pm
 Post subject: Manifold gaskets
PostPosted: Mon Aug 13, 2001 7:12 pm
Which ones are the best? Do some have bigger holes for the intake/exhaust passages? THANKS! Darrin
dartman225@webtv.net
 Post subject: Re: Manifold gaskets
PostPosted: Tue Aug 14, 2001 12:45 pm
: Which ones are the best? Do some have bigger
: holes for the intake/exhaust passages?
Use the gasket which matches you port size, the "stock" ones are a little bigger then the stock ports so they work in most cases.
Suppliers like Clifford and Mr. Gasket offer gaskets with bigger "cut-outs" and the Cox Boys have "racer specials" for real large port jobs.
The manifold gasket should never over-hang or cover the port opening in any way so tim it back if it does.
