It is currently Mon Nov 23, 2026 5:23 am
 Post subject: Reluctor wobble
PostPosted: Fri Apr 28, 2006 8:02 pm
I've heard that some reluctors were 'mis-cast' or had poor circumference. I'm told that you can't just file the blades to correct the uneveness and square up the clearance between reluctor and pickup (creates magnetic disturbance which confuses the computer). All that being said, I filed them anyway to get the proper clearance ALL AROUND. Is this a common problem with these or is it likely the shaft itself is warped or bent? I pulled the distributer out to do this and found it spins freely and the gear is fine. Since I did this however there is the odd time it won't start easily and the timing seems to bounce around a bit at the best of times. I tested my spark computer vacuum pod and it does hold vacuum.
Looks like a conversion might be sooner than I thought or it will be Do or Die! :roll:
Last edited by Slant n' Rant on Sat Apr 29, 2006 12:14 pm, edited 1 time in total.
PostPosted: Sat Apr 29, 2006 6:55 am
I just installed a new M/P electronic conversion in brother in laws 1972 D100, 318. The air gap was not adjusted at all right out of the box. I used an .008 brass feeler gauge to set air gap on the tightest reluctor. The other air gaps are off between .008-.010 .
PostPosted: Sat Apr 29, 2006 12:09 pm
I hear what youre saying, cant win for losing.
:twisted: < devil rejoices at the news of another purchase of mopar reluctor "soon we will take over all SLANTS, It will drive people crazy trying to gap it" HA HA HA "you are now under my control !"' :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock:
8) < slantsixdan- I told em' but they wouldnt listen
PostPosted: Sat Apr 29, 2006 4:27 pm
Must buy Chinpokomon.
 Post subject: Re: Reluctor wobble
PostPosted: Sat Apr 29, 2006 8:19 pm
I wonder if anybody has tried grinding them instead of filing them.
PostPosted: Sun Apr 30, 2006 7:23 am
OK, I've just spent 30 minutes searching the archives for information about Mopar Reluctors, reluctor gap, etc. and have found nothing about this. Please, no rolling eyes, no "I wish it would go away," just a straight answer or a link to where I can find the answer... what is this all about? Is there something inherently wrong with Mopar reluctors? What is the better alternative? Thanks in advance.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Mon May 01, 2006 4:01 am
I wouldn't worry too much about filing the points of the reluctor to make things even. There's no way that can "confuse" an ignition module, and unless you have Lean Burn, the "ECU" isn't a real computer anyway. A reluctor doesn't need quite the same degree of precision as a point type ignition. You should see some of the things that the guys in the Megasquirt forum have come up with for jury-rigged reluctors. One of the more common methods they have there is to simply put a half dozen bolts on the crankshaft pulley and set up a VR sensor that detects the passing bolt heads.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Tue May 02, 2006 10:12 pm
There's always a risk of posting what could be interpreted as "I've never seen it, therefore it doesn't exist" types of answers, but...
...the Mopar reluctors in question were used from 1971 through 1991. If there were really any kind of a widespread problem with them, it would be one of those legendary "goes with the territory" issues that everyone knows about and everyone remembers...like ballast resistors. It's certainly possible some bad OE (or bad aftermarket) reluctors got onto the market, but overall? Nope, they've been utterly problem-free.
PostPosted: Wed May 03, 2006 5:18 am
Thanks for the answer Dan. I've found that there are all kinds of apocryphal stories around about this part or that brand, etc. Sometimes it's difficult separating fact from legend.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Wed May 03, 2006 8:02 pm
If it is on the Internet, it must be TRUE!!!
