It is currently Wed May 20, 2026 11:18 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
PostPosted: Fri Aug 17, 2001 5:47 pm
Will the slant six mopar header fit with the clifford 4brl intake? Thanx Clint
kewda416ci@aol.com
PostPosted: Fri Aug 17, 2001 8:08 pm
: Will the slant six mopar header fit with the
: clifford 4brl intake? Thanx Clint
It will if you modify the #6 tube. An Offy will bolt right on. Dennis
aschumers@aol.com
PostPosted: Sat Aug 18, 2001 10:55 pm
: It will if you modify the #6 tube. An Offy will
: bolt right on. Dennis
What exactly do I have to modify, just wondering just incase its not that big of a deal, Clint
kewda416ci@aol.com
PostPosted: Sun Aug 19, 2001 4:20 am
: What exactly do I have to modify, just
: wondering just incase its not that big of a
: deal, Clint
On mine, the #6 tube makes a bend toward the front of the engine before it turns down. The tube needs to be changed so that it comes straight out until it turns down. Not sure why they put the dogleg in there, but it's gotta come out. Dennis
aschumers@aol.com
