It is currently Mon Nov 23, 2026 3:57 am
 Post subject: engine help/ new member
PostPosted: Wed May 03, 2006 1:23 pm
hello,
i am new to this forum and i am experiencing several problems with my 1985 225 /6.
first: on a cold start engine starts, then stalls almost imediatly. requiring wot to warm up.
after engine is at operating temperature, it has a very noticeable miss,
shaking,
very sluggish acceleration( accelerator to floor, 35 to55mph in 2.5 minutes)
has new plugs & wires, rotor, distributor cap, fuel filter/lines, air filter, pcv valve, breather, and ignition coil.
also, is it possible to remove the egr valve and install a cover plate in its place?
any help would be greatly appreciated.
thanks,
amos
1985 D100 2wd RC SWB 225/6 4spd
AMOS
PostPosted: Wed May 03, 2006 1:42 pm
Hello and welcome!
First off, does you truck have a lean burn or spark control computer? If so, I would suspect the computer.
It sounds like your choke is misadjusted and malfuntioning, and it also sounds like you have a vacuum leak. I would check your choke pulloff diaphragm and your vacuum advance pod on the distributor for leaks.
PostPosted: Wed May 03, 2006 6:08 pm
it has the holley 6145 feedback carb. i've always had trouble with this carb, either not having enough power, stalling or the like, since it was new. checked all vacuum lines/hoses-tight. carb bolts are tight, no leaks that i know of.
a local mechanic told me that the choke stove was bad. any clues?
by the way, the truck has sat for the past 4 years, with only an occasional cranking. is it possible that the float or needle valve is sticking?
also, i would like to convert to possibly a 2bbl carter bbd carb w/ intake/header & maybe a cam. does anyone have advice in this direction, or where i can get these parts?
i have electronic ignition, what does the vacuum advance pod, look like?
sorry for long post,
thanks, amos
AMOS
Users browsing this forum: Amazon [Bot] and 5 guests
