It is currently Tue Nov 17, 2026 9:10 am
Post new topic  Reply to topic  [ 39 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Wed May 03, 2006 9:27 pm
13 x 4.5"
PostPosted: Wed May 03, 2006 10:12 pm
13 x 4.5"
Thanks. Where in the world do you get stuff like that??
PostPosted: Thu May 04, 2006 12:10 am
13 x 4.5"
Old magazine articles, here, various forums, stamped on the wheel............
Incidently, there are 14x4.5" small bolt pattern wheels, so make sure they're 14x5.5"
PostPosted: Thu May 04, 2006 6:15 am
I think I need to either increase my tire diameter or get overdrive, considering where gas prices are going
Be careful with going taller. Taller tires give do change the effective gear ratio, but there are compromises. Some designs (say, significantly wider tires) have higher rolling resistance.
A tire and rim combination that is heavier or has a higher polar moment will take more oomph to accelerate or decelerate. At a steady speed, this may not mean much, but in the real world of daily driving, it adds up.
PostPosted: Thu May 04, 2006 7:13 am
13 x 4.5"
Gee whiz! Thanks
PostPosted: Thu May 04, 2006 7:18 am
It's looking suspiciously like this forum is a gold mine. Thanks.
PostPosted: Thu May 04, 2006 11:24 am
The best handling I ever got with the stock 13x4.5" wheels on my Valiants was with 175/70-13 tires. Anything wider on that skinny rim will just bulge the sidewall out and make the handling mushy. You are somewhat limited as to performance tires these days in that size but it will make you car steer pretty well as anything on the market now is superior to what we had 30 years ago.
"Former Owner" of '65 Barracuda, 225, Auto, MP 2bbl intake, MP cam, Dutra Duals. Presently Moparless.
PostPosted: Thu May 04, 2006 2:34 pm
Again considering gas prices, it might be as cheap to put in an overdrive (assuming it's possible to find one) as to find and buy 5 rims. Thanks
PostPosted: Thu May 04, 2006 2:46 pm
Larger tires may hurt.......
There's the previously mentioned higher weight....
But with the lower gearing you may end up putting the carb into the power (rich) circuit when accelerating and burn up more fuel............
PostPosted: Fri May 05, 2006 4:27 am
The only factory overdrive paired with a slant six was a '70s era version of the A-833. If you don't have a factory 4-speed, you will need to modify your transmission tunnel to install one.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Fri May 05, 2006 7:36 am
What you describe sounds more like understeer than oversteer.
I've never seemed to get that right. Every time I think I have it, I have it wrong.
It's easy: Understeer is when you hit the wall with the front of the car. Oversteer is when you hit the wall with the back of the car. :shock:
PostPosted: Fri May 05, 2006 9:09 am
Hmm, I have no urban driving and I may have more interstate driving coming up. I guess to be certain I should perhaps double check the rear end ratio? Do you happen to know the bottom ratio on my 3 speed? Thanks.
PostPosted: Fri May 05, 2006 9:15 am
The tunnels on the later A-bodies were larger? Giving room for either? Hmmm. I have one word for that. GACK!! Thanks for the heads up.
PostPosted: Fri May 05, 2006 9:25 am
Naw, the difference in the tunnel is floor shift vs. column shift. You have to add the floor shift "hump" if you're going from an automatic or a 3-on-the-tree to a 4-speed, because the 4-speeds are all floor-shifted. This isn't all that tough since there exist brand new shifter hump panels. They're intended for later cars, but can very easily be adapted to the earlier cars.
PostPosted: Fri May 05, 2006 9:27 am
Then I had it right. The radials seem to pull me into a sharper and sharper turn quicker compared to bias. With the bias plies it tended to stay on radius easier.
Mind you, I'm not talking race conditions. Just hills and curves. Thanks.
Users browsing this forum: Amazon [Bot] and 2 guests
