It is currently Mon May 11, 2026 8:24 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
 Post subject: Starter Choices
PostPosted: Sun Aug 19, 2001 8:53 am
The starter on my '80 Volare Sl6 is dying a slow death. I know the mini starters from Rams and Dakotas will work but are there any others I can try, like from the Chrysler powered mini-vans?
I'm planning on visiting the boneyard soon so any advice would be appreciated.
Also, since this will be the first time I've installed a starter, is there anything I should know about how to do it properly? I have the FSM handy. :-)
bmazur3@home.com
 Post subject: Re: Starter Choices
PostPosted: Sun Aug 19, 2001 10:41 am
: The starter on my '80 Volare Sl6 is dying a
: slow death. I know the mini starters from
: Rams and Dakotas will work but are there any
: others I can try, like from the Chrysler
: powered mini-vans?
No, front-wheel-drive starters do NOT fit rear-wheel-drive cars. If you want to play with the late-model mini Japanese starter, it's off any '89 or later RWD Chrysler-product V6 or V8. Jeep 6s and V8s are NOT included in the interchange.
: Also, since this will be the first time I've
: installed a starter, is there anything I
: should know about how to do it properly?
Remove negative battery cable from battery
Remove small and large cable connections from starter (do NOT lose washers and nuts)
5/8" wrenches to remove upper and lower starter fixing hardware
Remove starter, do NOT lose starter-to-bellhousing shim plate
Installation is the reverse of removal.
DS
redbear@vrx.net
PostPosted: Mon Aug 20, 2001 8:42 am
I made a view calls this morning and I can get a used mini-starter for $90 Cdn or a Wilson starter for $87. Is anyone familiar with the Wilson name?
bmazur3@home.com
