It is currently Wed May 13, 2026 7:08 am
PostPosted: Fri Apr 21, 2006 7:14 pm
I keep hearing about these lokar cables.... Is that an option for a single barrel holley? Or just for the 4 barrel? i haven't had a kickdown on my duster since I've had it, and now is the time to fix it. Any ideas suggestions or stifled laughter is always appreciated. Thanks!
kara
'70 Plymouth Duster 225
"A girl can fix stuff too! (sometimes.)"
PostPosted: Fri Apr 21, 2006 7:25 pm
It is best to find a stock 1-barrel kickdown linkage. These things are pretty common and a lot of people have them lying around after they have done two barrel conversions.
You did wire that kickdown lever at least halfway back all this time didn't ya? I hope so :shock: .
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Fri Apr 21, 2006 7:28 pm
yeah, once I figured out it was missing. However, I have no idea how long it was like that before I got it. Hopefully it isn't too messed up.
PostPosted: Fri Apr 21, 2006 7:37 pm
Post a want add in the parts wanted section for a complete kickdown setup for your application.
82 D150-225/727
PostPosted: Thu May 04, 2006 2:18 pm
Have a fellow who has a kickdown from a pickup. Could I use this or are they different? thanks.
k
PostPosted: Thu May 04, 2006 2:57 pm
Should be the same.
