It is currently Mon Nov 23, 2026 9:37 pm
 Post subject: spark plug tubes
PostPosted: Thu May 04, 2006 7:05 pm
Is it necesary to replace the spark plug tubes (the metal sleeves) when rebuilding an engine? I know there are supposed to be small o-rings that accompany them. I have a '66 225 that I am rebuilding and trying to do a good job with it. taking my time, but I am not building a race motor, just something with a tad more gusto (.060 over with CompCams 252 cam).
So replace spark plug sleeves or not necessary?
Caesar
PostPosted: Thu May 04, 2006 7:19 pm
Naw, as long as they aren't beat up I don't see why. Inspect the chamber end of them to make sure they are flat and don't have any sharp edges. If they do file them flat and clean up any metal powder so it doesn't enter the engine.
The seals are availible aftermarket as well, felpro ES12794. Just to be clear - these seal the tube to the outside of the head, there is no o-ring that seals it to the inside of the head. That is done by the spark plug pinching the sleeve between it and the head.
PostPosted: Fri May 05, 2006 2:28 am
I got them tubes as a set from ebay... at the very reasonable cost of $20 plus shipping. Gonna see if I have seller's ID so I can pass it on to you.
Juan Ignacio Caino
PostPosted: Fri May 05, 2006 4:10 am
I believe this is the item on ebay if your talking about the rings and not the tubes.
http://cgi.ebay.com/ebaymotors/NOS-MoPa ... enameZWD1V
PostPosted: Fri May 05, 2006 4:43 am
no I'm talkin bout the tubes themselves.
Juan Ignacio Caino
 Post subject: all helpful
PostPosted: Fri May 05, 2006 12:22 pm
all that info was helpful. I appreciate it
caesar
PostPosted: Fri May 05, 2006 1:32 pm
That's ridiculous...........
PostPosted: Fri May 05, 2006 2:00 pm
What is? The $9.95 price? How much do pay for them? If I remember corectly, the last ones I got at NAPA were a little over $1.00 ea, so that price is not outragous, but with shipping figured in, it is better to get them locally.
PostPosted: Fri May 05, 2006 2:45 pm
Doesn't say seal kit, so that's $9.95 each...........which is ridiculous.....
It's $3.49 a set at Rock Auto (plus shipping, but I wouldn't order it alone)
PostPosted: Fri May 05, 2006 3:10 pm
Ooofff... picutre is of one seal, no where does he use plural "seals" anywhere, methinks it is for a single seal.
PostPosted: Fri May 05, 2006 3:38 pm
Car Model: '23 T-bucket
C'mon you guys! Ain't you been watching the B-J auctions?! Everybody knows anything Mopar is selling for premium prices, so the parts automatically get more expensive! :roll: :wink:
Roger
PostPosted: Fri May 05, 2006 4:04 pm
Keep in mind, if you get an engine rebuild kit or a gasket kit, it should include the tube gaskets. Also don't forget to cut metal ring off the spark plugs before installing them. I always forget that.
Steve
1966 Dart GT
PostPosted: Fri May 05, 2006 4:41 pm
I never cut them off............
I unscrew them :P
 Post subject: metal ring/washer
PostPosted: Fri May 05, 2006 8:20 pm
I am supposed to remove that metal washer/ring that is on the threaded side of the spark plug? I never knew that. What is the reason behind this?
Caesar
 Post subject: Re: metal ring/washer
PostPosted: Fri May 05, 2006 8:49 pm
Caesar
60-62 use the tubes and the washers
63up (until there's no tubes) use just the tubes.
The tube takes the place of the washer/seal for 63up
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot], Google [Bot] and 5 guests
