It is currently Fri May 15, 2026 2:03 pm
 Post subject: help me ID my booster.
PostPosted: Fri May 05, 2006 1:32 pm
my booster is leaking and so I am back to manual breaks. the booster mounts to a bracke that mounts to the fire wall with teh same pattern as a regular single or dual master bolt patern. It sits up high, is sort of long and narrow and can easily be removed to replace things (in my case, I yanked it out to pull the stearing gear.)
I think i got it from a 76 swinger, but i could be mistaken. It may be from a much earlier year. it amy be from a 69 swinger.
any help would be greatly apreciated.
63 valient 4 speed over drive, holly 390, dutra duals, power steering, ac, hydraulic roof, KH 4 piston disks, kyb gas adjust all round, sway bars front and rear, 8 3/4 rear axcel and the ugliest green you ever saw
PostPosted: Fri May 05, 2006 3:18 pm
You can have brake boosters rebuilt. At this late date, most of the used units still washing around in the market are at or near their failure point.
Go-to guy is:
"Booster" Dewey Website
Power Brake Booster Exchange
Phone # - 503-238-8882
4533 SE Division St.
Portland, OR 97206
PostPosted: Wed May 10, 2006 7:19 pm
thanks dan, I will be in oregon next week or so anyway! The think whistles when I step on the brake hard. and the pedal is hard to push.
thanks again Dan.
PostPosted: Wed May 24, 2006 11:20 pm
dewey did a great job, car is happy again! Thanks!~
