It is currently Tue Nov 24, 2026 11:50 pm
PostPosted: Mon May 08, 2006 2:46 pm
If a 2bbl would work with a turbo???
Oh yeah! :twisted:
PostPosted: Mon May 08, 2006 2:48 pm
Think it's worth $200?
From a performance standpoint? Nah. It's just not too different (if it's different at all, which is debateable) from the production iron 2bbl intake. From a weight saving standpoint? Probably still not, given that there are other ways of removing or redistributing weight that cost less.
Think a 2bbl would work on a turbo? :twisted:
Can't see any reason why a 2bbl would be any less appropriate than any other choice...!
PostPosted: Mon May 08, 2006 4:30 pm
Perhaps I should explain better.
Can a 2 bbl be made to run well both with and without boost?
A 4 bbl has a set of secondary jets that can be increased tp provide enough fuel under boost. A 2 bbl would have to do it through the power circuit. Can it be made to handle the flow?
Not looking to build a racecar, I need it to work both on and off power. :wink:
'15 Chrysler 200S V6
'74 Duster 360, factory 4 speed car
PostPosted: Mon May 08, 2006 5:37 pm
So, if i take a 1bl. manifold and just machine a new carb mounting pad, i'd have a supersix intake right?
Thanks for your help reed.
Marc
I did this mod many years ago, worked great. I tried a Holley 350 2bbl
and found it hard to get tuned then I switched to a Carter 318 2bbl and
that was prety much a bolt on. Just adjust the Idle jets and it ran fine.
My advice ... if you are not sure what you are doing ......
follow the instruction given by the other guy. ... he sounds like he knows
what he is doing.
When I did this mod I turned the carb to be paralle for better gas
distrubition but it does cause some problems working out kick-down
linkage and on my 62 Valiant I switched to cable throtle linkage from
the stock mechanical linkage (made that part a little easier).
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 5 guests
