It is currently Thu May 21, 2026 11:08 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 5 posts ]
 Post subject: 3 speed overdrive tranny
PostPosted: Wed Aug 22, 2001 7:56 pm
My car is pitiful on take off. Was thinking of putting a little taller gear with a 3 speed overdrive tranny. Are there any years that may be better than others. Sorry guys.....converted Ford man! Still learning the Mopar ropes.
ripster1@tampabay.rr.com
PostPosted: Wed Aug 22, 2001 8:58 pm
: My car is pitiful on take off. Was thinking of
: putting a little taller gear with a 3 speed
: overdrive tranny. Are there any years that
: may be better than others. Sorry
: guys.....converted Ford man! Still learning
: the Mopar ropes.
What do you have?
If you have a 1975-1987 3spd+OD tranny you have a pretty granny 1st (3.09:1) and they are all the same from 1975-1987.
res0aus2@verizon.net
PostPosted: Wed Aug 22, 2001 9:13 pm
: What do you have?
: If you have a 1975-1987 3spd+OD tranny you have
: a pretty granny 1st (3.09:1) and they are
: all the same from 1975-1987.
: -D.Idiot
I have a 73 Duster D.Idiot....thanks
PostPosted: Wed Aug 22, 2001 10:09 pm
: I have a 73 Duster D.Idiot....thanks
You might want to change the fluids, and if she's *realllly* sluggish you might check your clutch disc....
otherwise, more power wouldn't hurt...time to find that super six.
76 Feather Duster
PostPosted: Sat Aug 25, 2001 12:37 pm
: the Mopar ropes.
if you have the O.D you already have the stump pullin 3.09 first gear...the bogs usually the wide spread from first to second......i'd have to agree the motors not up to snuff.
