It is currently Fri May 15, 2026 7:59 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
 Post subject: 5 speed transmission???
PostPosted: Sun Aug 26, 2001 11:46 pm
What kind of car(s) can I look for that has the 5 speed I need to put into my cuda in place of the now 4 speed? Thanx
kewda416ci@aol.com
PostPosted: Mon Aug 27, 2001 4:01 pm
You might be able to use a T-5 if you can make some mods, a pilot bearing adapter etc. I think the Mopar input shaft is longer than what a T5 comes with, but some GM T5s that have a 9" input shaft can be made to work.
The cross member will need to be reworked. I don't know the specifics, but it can be done. I think the task is worth the effort.
You might be able to purchase a kit to do most of the mods from this site :
<A HREF="http://www.rodshop.com.au/transmissions ... ons.htm</A>
: What kind of car(s) can I look for that has the
: 5 speed I need to put into my cuda in place
: of the now 4 speed? Thanx
http://www.rodshop.com.au/transmissions.htm
tkeith@mindspring.com
