It is currently Wed Nov 25, 2026 6:17 pm
 Post subject: perfromance ?'s
PostPosted: Sun May 14, 2006 10:23 am
my 225 /6 in '85 dodge trk, is quite underpowered and giving me trouble.
is it possible to install a larger carb, is a 2bbl intake needed for this? also are there any other mods. that can be done, performance wise?
thank you,
amos
1985 D100 2wd RC SWB 225/6 4spd
AMOS
PostPosted: Sun May 14, 2006 4:31 pm
Yes, and you will need a 2-bbl manifold if you want to put on a larger carb. Best bet is a junkyard Super Six manifold.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Sun May 14, 2006 10:30 pm
which autos would have the super six manifold, and what 2bbl would be best to go with for power/fuel economy?
thanks,
amos
AMOS
PostPosted: Sun May 14, 2006 10:33 pm
also, would it be possible to change the distributor from the electronic timing advance type to a distributor advance type?
amos
AMOS
PostPosted: Sun May 14, 2006 10:37 pm
edit: vacuum advance distributor from comp. controlled advance.
amos
AMOS
PostPosted: Mon May 15, 2006 10:36 pm
http://www.slantsix.org/forum/viewtopic.php?t=15779
http://www.slantsix.org/articles/supersix/article.htm
The first one is on the HEI conversion, the second is on the super six conversion.
Cheers!
Allen
1962 Valiant V-200
170 C.I. Super Six, HEI, Dutra Duals
