It is currently Fri Jun 12, 2026 5:52 pm
 Post subject: Steering danger?
PostPosted: Tue May 16, 2006 10:35 am
There's a collar just below my steering coupling that actually looks like part of the coupling. There's a countersunk hole through it - not centered but apparently through part of the shaft. Shouldn't there be a pin or bolt or something in that hole? I'm guessing it must be rusted in place, but. . .
PostPosted: Tue May 16, 2006 2:07 pm
Ross,
There is a roll pin that goes through that hole. The shaft on the steering box is shaped like this:
<pre>
) (O<-----roll pin
</pre>
The roll pin might be there. It's a split hollow tube, so you might just be looking right through it.
Can't get my ASCII graphic to work, even with the HTML preformatting tags.
'68 Dodge Dart 4dr Sedan
