It is currently Thu Jun 04, 2026 3:51 am
PostPosted: Sat May 20, 2006 7:35 am
Car Model: 1967 Dodge Dart 270
I am changing over my 74 Duster from power to manual steering. (race car)I need to know what year/style pitman arm will work with the smaller diameter manual box steering gear. The manual box is out of a 71 A body. Would a pitman arm from a 74 A body with factory manual steering work? The pitman arm off the 71 will not work because the steering centerlink is different. Any help or ideas will be great. Thanks, Brian
PostPosted: Sat May 20, 2006 7:41 am
I am fairly sure this is a "no go" deal. Unless I'm misremembering, both power and manual steering got the large pitman shaft for '73. But, I could easily be wrong. Looking at BigBlockDart's Steering/Suspension Parts Guide, it looks like '73-'76 A-bodies had different pitman arms for power vs. manual, so perhaps a K7075 (Moog number) will get the job done for you.
PostPosted: Sat May 20, 2006 8:06 am
Thanks Dan. I will look into the Moog K7075 and check the pitman shaft diameter to see if it will work. If not, I can find a 73 & up manual box.
PostPosted: Sat May 20, 2006 9:43 am
