It is currently Wed Apr 29, 2026 7:59 pm
PostPosted: Sun May 21, 2006 3:08 pm
This thing is great! So far, all I have had to do is jet it down 2 sizes. It flat works great. I don't know why I didn't switch to this 600 double pumper years ago. That 390 of mine is a toilet plunger compared to this carb. :lol:
I guess now I'll leave the 390's to the street guys who want to go slow. :roll:
At least a bad 390 is still better than a good Edelbrock or Carter. :twisted: :twisted: :twisted: :twisted: :twisted: :twisted:
Hi Mike! :D
PostPosted: Sun May 21, 2006 6:47 pm
Always fun to set a low ET with your car with new parts... If it's good enough for the Buzzin' car, it's good enough for your red wagon, eh?
 Post subject: Bwahahahhaaaa!!
PostPosted: Sun May 21, 2006 6:54 pm
You know I noticed that when I went from the 8007-390cfm to a 600 cfm with annualar venturies...the pickup and top end were awesome...since I couldn't get my foot "off" the accelerator, my gas mileage went south... :roll:
Cool, Big D!!!
I'm actually about to try "the best of both worlds" and am working up a 465 cfm Holley with annular primaries...so I should have a fair compromise between "mileage" and "POWER" :twisted:
PostPosted: Mon May 22, 2006 5:18 am
Mileage? What is this mileage you speak of? :shock: :lol:
Lou, yeah going fast is good. I am gonna try a couple things yet and hopefully will get this thing into the 11's in street trim. As it sits now it is completely street legal w/plates and insurance on it. :roll: :shock:
PostPosted: Mon May 22, 2006 1:23 pm
What jets are stock in these anyways??
Last edited by featherduster76 on Mon May 22, 2006 1:25 pm, edited 1 time in total.
 Post subject: That's right!!!!
PostPosted: Mon May 22, 2006 1:24 pm
I forgot you are still using the "runs per tank" measurement.... :lol:
 Post subject: Re: That's right!!!!
PostPosted: Mon May 22, 2006 3:07 pm
Yep, fuel and bottle both. :lol:
Mine had 68's in front and 74's in back. I went down 2 steps both sides. :shock:
PostPosted: Mon May 22, 2006 5:29 pm
Car Model: 1964 Dart GT
I was talked into getting a 390. It costs twice as much and now I hear it doesn't work as well on a slant? After my 390 dumped fuel all over my engine for the third time not due to over pressure I took it apart and found that the float had a rough part that was hanging up on the needlevalve. Now that I will be using a Paxton, I decided on trying a Demon blow through. I have heard good and bad so what the hell, its only $560!
PostPosted: Tue May 23, 2006 1:14 am
Andy,
The carb Slantzilla has is a 600 double pumper not the 1850 Holley vacuum secondary 600. It's a more expensive carb.
I had my 390 flood a couple times due to a speck of dirt on the needle valve. At least it's easy to fix the on a Holley. No fuel line removal required.
Annular boosters do work well. In fact they are the best Holley booster. The straight-leg boosters in the 390 are the worst performing boosters with the down-leg boosters being in the middle somewhere. The Barry Grant Road Demon 525 has annular boosters on both primary and secondary side. They also have 4 corner idle, electric choke, and quick change vacuum secondary springs. $340 new doesn't seem too bad for all that. The 575 Speed Demon also has all those features and should be a great carb for folks running more than cam duration, but they run $400.
PostPosted: Tue May 23, 2006 12:09 pm
Seconded!
what fuel pump are you using now? if you weren't runnin' goofy gas would you use the same pump still?
-dave
what part of "illegal" is so confusing???
PostPosted: Tue May 23, 2006 1:14 pm
Andy,
I actually did catch that one... :?
The Demon Mighty Demon blow though#5282010BT is the one I will be using on my supercharged slant.
PostPosted: Tue May 23, 2006 2:26 pm
Make sure you disassemble it and look for undrilled passages, and clean out all the junk before you use it. BG quality sucks. :shock:
PostPosted: Tue May 23, 2006 2:58 pm
SSRN National Champion
Bagel is right on this. Have a MOPAR racing friend with a small block crate engine put on a brand new BG and it was a dog stumbled, could not adjust ect. Took it apart it was full of metal shavings and junk. If i was going to buy another racing carb i would buy a Holly racing carb modified by Keith Dorton. I have a 390 cfm KD double pumper that came off of a NASCAR Craftsman truck engine will smoke on a stock Slant. But would not sell it at this time Thanks Ron Parker :D
I love the smell of burnt Bagels in the morning
PostPosted: Tue May 23, 2006 3:09 pm
I have used 2 in the past without any problems. Maybe just lucky so far. What is selling me on this one is it is blow through ready. I will let you know how it works. :shock:
PostPosted: Wed May 24, 2006 12:09 pm
so, what fuel pump are you using, and would you use the same thing without the bottle?
-dave
