It is currently Mon Oct 12, 2026 9:55 pm
Post new topic  Reply to topic  [ 16 posts ]  Go to page Previous 1 2
PostPosted: Thu May 25, 2006 8:48 am
3) deck the block 100 thou (these crazy 6s have a super low 8.4:1 compresson ration that needs to be brought up.)
You might want to check your particular engine before taking off that much anywhere. There is a lot of variation in chamber size, head gasket thickness, etc. Has the deck or head been machined before? A cleanup pass on the head will take up some of that, and a pass on the block a little more.
It would be easy to mill yourself into a higher octane fuel requirement, something a daily driver doesn't need.
By the way, it wasn't just sixes of the era that had low compression ratios. There are lots of four-bangers and bent-eights with similar numbers.
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 289 guests
