It is currently Tue Nov 24, 2026 6:09 am
 Post subject: sway bar recomendations
PostPosted: Sat May 27, 2006 8:34 pm
I have a 64 valiant with no factory sway bar. looking to do front and rear at same time. anyone have brand recomendations? any problem installing the kits? FFI looks like there stuff is pretty well enginered for A bodies. any comments?
64' Valiant Signet 5.9, 64' Dart 170 moredoor 3.7, 67' A100 3.7, 00' Dakota SLT 4.7
PostPosted: Sat May 27, 2006 8:56 pm
I'm using addco F/R
1 1/8" , 3/4"
Just need to drill a couple of holes.
See
http://www.slantsix.org/forum/viewtopic ... co+valiant
PostPosted: Sun May 28, 2006 6:37 am
How does the rear bar hang? is it above or below the rear end?
PostPosted: Sun May 28, 2006 9:11 am
I have an Addco front bar. It's a real handling improvement, but I do not like the way the brackets mount to the K-member. They hang down enough that with stock torsion bars, hitting a hard bump can bottom out the brackets. Not good.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Sun May 28, 2006 9:17 am
From emsvitil pics. I didn't like the way the brackets lined up under the K frame. two squares at different angles you could always trim off the excess. The firm feel brackets I thought looked like a cleaner install with better ground clearance.
PostPosted: Sun May 28, 2006 3:11 pm
I haven't had a problem with hitting the brackets. With a little grinding I could even get them fully out of the way. I may have managed to mount them higher on the K-member than you did..........
PostPosted: Sun May 28, 2006 3:14 pm
I will agree that firm feel has a better mounting system in front (and probably rear).........
But for the cost of 1 bar at firm feel you can get the pair of addco bars.............
