It is currently Fri May 08, 2026 1:51 pm
PostPosted: Mon May 29, 2006 3:16 pm
What if I had a piece shaped like this?
Compress clay/playdough balls under points A and B as the plate is held parallel to the sway bar.
The clay would give you the thickness and angles for the two wedge-shaped spacers.
Bolts at A and B would go through the K
I would probably file/grind the spacers from soft aluminum.
The L-bracket could still reinforce hole C.
Would the L-bracket be overkill if this mounts to the K-frame at two points?
Would the triangular piece be too ugly?
Doesn't even need to be that complicated.....
Keep the Lower mounting point (with the L Bracket), and extend the upper bolt thru the K-member. The spacers are just because of the slightly different angles of the brackets and K-member.
Like this (look at last picture at top of thread too)
PostPosted: Mon May 29, 2006 6:55 pm
That is simpler. What happened to Lou's pics?
How did he do it on his 64?
PostPosted: Mon May 29, 2006 7:57 pm
My webspace died for some reason. Need to get it running. On my 64 I just welded the addco mounts solid and welded them to the K near the front where the strut rod washers sit.
PostPosted: Mon May 29, 2006 8:44 pm
Car Model: 1962 Lancer 770
sorry moved stuff around on my website and didn't realize the links were broken. They're fixed now.
