It is currently Sat Oct 10, 2026 11:47 pm
PostPosted: Wed May 31, 2006 5:13 pm
I have a 225 in a boat and looking for some easy ways to increase horsepower...can any one give me some suggestions?
PostPosted: Wed May 31, 2006 6:27 pm
What are you starting off with? What kind of carburation do you have? Any other mods already done to the engine?
How big of a boat?
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Wed May 31, 2006 6:58 pm
No other mods that I know of...I think it has a factory carb on it now not sure.
1969 Chyrsler Carvell 21 ft. cudy cabin
I have been restoring for about three months now and just now getting to the motor I will have pics when its done. Its going to be nice... fully restored from the bottom up.
PostPosted: Wed May 31, 2006 8:13 pm
Cudy cabin
PostPosted: Wed May 31, 2006 8:42 pm
Im almost positive it's a 1-barrel carb
I can take a picture of the engine and post it if nessesary...
PostPosted: Wed May 31, 2006 8:47 pm
Whoops, let's not let this thread drift off topic before it can even get started. We can discuss "cudies" (...?) over in the social forum, if we must.
Carvel, a lot of the automotive-type upgrades for the slant-6 are also applicable to a marine engine, with the caveat that marine applications require consideration for the marine operating environment. A 2bbl carburetor would likely help quite a bit, as would an electronic ignition system with an application-matched advance curve. But, with that 2bbl swap, you'd need to find an air cleaner suitable for the particular type of marine installation you've got, and you'd want to pick your carburetor carefully. The pictures you've mentioned will be a great help, for they will allow us to see what you've got now in terms of air cleaner, carb and other ancillaries.
PostPosted: Wed May 31, 2006 9:46 pm
It's more complicated than just finding a correct air cleaner. Marine carbs are significantly different in many respects, particularly the vent and the throttle shaft bushings (so that there is no chance of fuel leakage). Unless you can find an OEM marine BBD (doubtful, it would seem to me), I think you're best bet would be to grab one of the smaller Holley 2300 marine carbs and either run an adapter plate or a manifold w/ the correct flange pattern.
PostPosted: Thu Jun 01, 2006 3:47 pm
Always hotties in the cabin cuddling... :P
I have pics of those also... this may sound stupid to all you computer wizards but how would I attach a pic to the discussion?
PostPosted: Thu Jun 01, 2006 6:27 pm
See this thread for info. on posting pictures:
http://www.slantsix.org/forum/viewtopic.php?t=4434
Users browsing this forum: Amazon [Bot] and 6 guests
