It is currently Sat May 16, 2026 5:27 am
PostPosted: Wed Sep 12, 2001 3:38 pm
I am in desperate need of a couple of cables for a 64' Dodge Dart w/ slant six and pushbutton transmission. They are a "Shift Level Cable"
(Dodge part # 4-10-01) and a
"Speedo Cable"(Dodge part # 21-84-1).
Thanks in advance
Tim Walker :)
silaswalker@netscape.net
PostPosted: Wed Sep 12, 2001 6:02 pm
: I am in desperate need of a couple of cables
: for a 64' Dodge Dart w/ slant six and
: pushbutton transmission. They are a
: "Shift Level Cable"
: (Dodge part # 4-10-01) and a
: "Speedo Cable"(Dodge part # 21-84-1).
Tim,
Are you in need or the "PARK" Lever cable??
The 64 Dart is pushbutton so I'm confused by that discription.
There is a "gear selection" cable and a seperate "park lever" cable so let's figure-out which one it is.
The speedo cable "core" can be purchased just about anywhere as a "cut to length" kit. If you need the outer housing with the inner cable, those can be found on any 62-66 A-Body. (It may even go back as far as 1960)
