It is currently Wed May 27, 2026 4:27 pm
PostPosted: Wed May 24, 2006 10:14 am
I'll probably find it eventually on my own, but if anyone could please tell me the physical location of the horn relay/ignition buzzer on a '71 Dart, I'd be most grateful. It's clever how they added another set of contacts to the horn relay so it would serve as a "key in ignition" buzzer and all, but the buzzer's driving me buzzy and I want to deactivate it <i>stat</i>, so any help's appreciated. Behind the kick panel, maybe...?
PostPosted: Wed May 24, 2006 2:57 pm
hiya dan-
if memory serves, it should be high above the left kickpanel screwed to the body with a black, purple and red or green wire? i think my girlfriend packed up all my service manuals for our big move. sorry, it's been a while since i've been under the dash of my '70.
-james
PostPosted: Wed May 24, 2006 6:49 pm
Check around the glovebox(you probably knew that) and on the fuse box. On my 74 Duster the buzzer is a seperate, two-pronged relay all together. I just pulled it and it hasn't caused any more problems.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Mon Jun 05, 2006 11:42 am
Just got a clean 74 Dart swinger and the buzzer isn't working. Until I determine on my own I don't want the buzzer, I'd like to get it working. Is it around the glovebox, or above the left kickpanel? There's nothing special about it, correct? Other than when you put the key in the ignition, it should go on...right?
PostPosted: Mon Jun 05, 2006 3:16 pm
Look around the fusepanel. It is a little two pronged box.
Key in ignition and door open it should be buzzing. Drives me nuts.
82 D150-225/727
PostPosted: Mon Jun 05, 2006 3:30 pm
hiya dan-
'Zactly! I reached up, found the one thin-gauge wire running to it, pulled it off, and the buzzer stopped buzzing but the horn still works. Perfect! Thanks.
 Post subject: thanks
PostPosted: Tue Jun 06, 2006 11:57 am
thanks Jeb.
