It is currently Fri Nov 13, 2026 7:18 am
 Post subject: converter?
PostPosted: Wed Jun 07, 2006 9:45 am
what would be a good stall speed for a basically stock rebuilt 225 with a 390 and 904 trans being rebuilt with a shift kit in it. i have 2.76 gears but will be going to 3.23. stall speed?
thanks
dustin
PostPosted: Wed Jun 07, 2006 12:15 pm
I like as much stall as possible. I ran a very similar combination with a 3000 and it worked very well. :shock:
PostPosted: Wed Jun 07, 2006 1:44 pm
Dennis, did you have an auxillary trans fluid cooler with that converter (or any high stall converter really)? I know my truck barely turns 3000 rpm at 75 mph with 2.76 gearing (and small tires, works out to about a 3.00:1 effective rear ratio). Seems like that 'loose' of a converter would build a lot of heat on the street. Just curious. :?:
PostPosted: Wed Jun 07, 2006 1:47 pm
For comparison on my stock 64, I stomped on the brakes and floored it...........
The converter stalled at 1750 rpm.
PostPosted: Wed Jun 07, 2006 2:56 pm
Contrary to what many would like you to believe, a loose converter will not necessarily be slipping going down the road. I have had daily drivers with converters as loose as 3800 with no troubles. Yes, I aslways run an auxillary cooler. :shock:
