It is currently Mon Nov 23, 2026 8:33 am
 Post subject: side updraft carb?
PostPosted: Wed Jun 07, 2006 3:02 pm
Car Model: 1967 Dodge Dart GT
i read somewhere, here most likely, that the clark cortez motorhomes had sideupdraft carbs, i dont know what that is, i am really curious, is the whole manifold different? whats the hp/torque on those? any info appreciated!
PostPosted: Wed Jun 07, 2006 3:09 pm
The Clark Cortez used a single horizontal (or "sidedraught" -- not "side updraught", no such thing) Carter YH carburetor mounted on a special intake manifold that had the regular top mounting flange blocked off with a plate. The YH carb was mounted to a mounting flange on the outboard vertical surface of the intake manifold (where the EGR valve is on late-model intakes, via a different flange). Horsepower on that 225 engine in the Cortez was 127, compared to the standard 225's 145.
