It is currently Thu Jul 02, 2026 4:08 pm
PostPosted: Thu Jun 08, 2006 1:01 pm
I have a 74 Swinger. it's beautiful. It's dashboard has a round 'fasten seat belt' warning light, located beneath the fuel gauge.
I have noticed that on some 74 and 75 Custom/SE models, there's another...something located next to this light, beneath the temp gauge. Whatever it is, my 74 Swinger doesn't have it.
Here's a link to a photo of one.
What is this? another warning light? or something else?
PostPosted: Thu Jun 08, 2006 4:12 pm
That would be the EGR warning light. Look under the hood. There is a rubber covered thingy that connects the lower part of the speedo cable to a shorter upper part. I believe it is some sort of mileage counter that warns that it is time to check the egr. I just unplugged the wires on mine. My egr is working fine and that little dash light is really bright red and kind of annoying.
 Post subject: thanks!
PostPosted: Fri Jun 09, 2006 12:37 pm
hmm. interesting, all these archaic 70's safety features!
 Post subject: EGR light
PostPosted: Mon Jun 12, 2006 11:23 am
74DartSwinger is absolutely right;
the EGR light was run by a little clockwork mechanism off the speedometer cable that didn't "know" anything about the EGR, it was just a reminder to check it every so many thousand miles. Normally, one could use an allen wrench to reset the clockwork for another round.
I combined the EGR light with the Fuel Pacer control to make a Yee-Haw light that congradulates the driver for stomping on it. The hard part was the legend - a bulb overheated it, so I made a bright LED replacement for the bulb.
 Post subject: interesting
PostPosted: Mon Jun 12, 2006 1:48 pm
you guys seem to know all about these lights. what about the light next to it; the fasten seat belt light? does the light work on your car? do you have that Seatbelt/interlock safety function working? or does the light just not work?
 Post subject: Yep...
PostPosted: Tue Jun 13, 2006 9:12 am
Yep, and if in working order has an accompanying buzzer that goes on for 5 seconds until you belt in, or it just goes out via timer... Goes with the interlock system (sensor in the seat meshing) on pre-75 cars...after 75 it may have a system tied to the seatbelt that just cuts out the buzzer...
 Post subject: i.e.,
PostPosted: Tue Jun 13, 2006 1:18 pm
so if the interlock system has been disabled, the light on the dash won't work?
i have the buzzer working - it's just the key in the ignition, when the door's opened. when the key's in the ignition and the door's shut, it doesn't buzz at all...
PostPosted: Tue Jun 13, 2006 10:24 pm
I am getting ready to install some of those cool hard back buckets from a 67 cuda in place of the bench seat. I am pretty sure that the buzzer is just straight connected through the belts not a seat sensor. But I guess I will find out the truth to that . I'll let you know if I remember!
Users browsing this forum: Amazon [Bot] and 2 guests
