It is currently Mon Nov 23, 2026 12:14 am
PostPosted: Mon Jun 12, 2006 4:13 am
My new torsion bars are marked R and L. So assume that Left is Driver side and Right is Passenger side. Also, how do I know which end goes where? It seems like if there is a left and right then it matters which end points forward and the other back.
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Mon Jun 12, 2006 7:43 am
That debate has raged forever as to which end goes where. They are normally installed with the L or R to the rear though. :shock:
PostPosted: Mon Jun 12, 2006 8:02 am
I just drew a picture of the set-up and doesn't appear to matter. The twist applied to the bar is in the same direction no matter which end you install to the front. As long as you have the R bar on the right and the L bar on the left. I am assuming that the R bar is the passenger side and the L bar is the driver side.
bwhitejr
0.090 Shaved Head
PostPosted: Mon Jun 12, 2006 11:39 am
You are correct on the L and R placement, and I don't think it matters which end goes where.
PostPosted: Mon Jun 12, 2006 4:12 pm
True, but it's a lot easier to read the part number when it's at the back.
