It is currently Tue May 19, 2026 4:44 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
 Post subject: Retainers and locks?
PostPosted: Sun Sep 23, 2001 11:58 pm
I'm seriously thinking of installing larger valves in my /6 head. The guides are wasted on my replacement head, so I figure i'll be half way there, but I'm not sure what to do about retainers and locks. If I go with the 11/32 stems do I just need larger retainers and use the 11/32 locks? is there any special lock that will take the extra space in the 3/8 retainer? Has anyone used the "special" 30 degree valve angle, is it worth the extra time on the valve grinder?
Fourgasman@aol.com
 Post subject: Re: Retainers and locks?
PostPosted: Mon Sep 24, 2001 9:36 am
: I'm seriously thinking of installing larger
: valves in my /6 head. The guides are wasted
: on my replacement head, so I figure i'll be
: half way there, but I'm not sure what to do
: about retainers and locks. If I go with the
: 11/32 stems do I just need larger retainers
: and use the 11/32 locks? is there any
: special lock that will take the extra space
: in the 3/8 retainer? Has anyone used the
: "special" 30 degree valve angle,
: is it worth the extra time on the valve
: grinder?
I have just used springs, locks, and retainers that go with the valves I am using, and have the spring seats machined to fit.
PostPosted: Tue Sep 25, 2001 5:06 am
I'm actually trying to avoid as much money going to the machine shop as posible, other options would be apreciated.
Fourgasman@aol.com
