It is currently Thu May 21, 2026 12:45 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
 Post subject: Holley #1920
PostPosted: Mon Sep 24, 2001 5:27 am
Can anyone tell me the cfm of the Holley # 1920 carb?
reptylkrib@aol.com
PostPosted: Mon Sep 24, 2001 6:50 am
According to information in a book, Holley Carburetors & Manifolds, that I have. . .
The 1920 carb came in flow capacities of 160 and 235 CFM (flow at 3.0 inches Hg). Throttle bores are 1-9/16 and 1-11/16 inch.
The 1945 carb came in one size wilth a 1-11/16-inch throttle bore and flows 203 CFM at 3.0-inch Hg pressure drop.
(Hg is the chemical symbol for mercury. Most vacuum gauges we use here are calibrated to read in "Inches of Hg" meaning "inches of mercury".)
NOTE - You can NOT directly compare CFM rating of 1- and 2-bbl carbs to ratings of 4-bbl carbs. 4-bbl carbs are usually rated at 1.5 inches Hg pressure drop whereas 1- and 2-bbl carbs are rated at 3 in. Hg pressure drop.
To relate the two measurements, use the formula
CFM flow at 3 in. Hg / 1.414 = Equivalent flow at 1.5 in. Hg
Example: for a 235 CFM 1-bbl carb
235 / 1.414 = 166 CFM four-barrel equivalent
Hope this helps.
CF
cfield@ll.net
PostPosted: Tue Sep 25, 2001 5:05 am
Thanks, this is just what I needed to know!
God bless America!
Dan
: According to information in a book, Holley
: Carburetors & Manifolds, that I have. .
: The 1920 carb came in flow capacities of 160
: and 235 CFM (flow at 3.0 inches Hg).
: Throttle bores are 1-9/16 and 1-11/16 inch.
: The 1945 carb came in one size wilth a
: 1-11/16-inch throttle bore and flows 203 CFM
: at 3.0-inch Hg pressure drop.
: (Hg is the chemical symbol for mercury. Most
: vacuum gauges we use here are calibrated to
: read in "Inches of Hg" meaning
: "inches of mercury".)
: NOTE - You can NOT directly compare CFM rating
: of 1- and 2-bbl carbs to ratings of 4-bbl
: carbs. 4-bbl carbs are usually rated at 1.5
: inches Hg pressure drop whereas 1- and 2-bbl
: carbs are rated at 3 in. Hg pressure drop.
: To relate the two measurements, use the formula
: CFM flow at 3 in. Hg / 1.414 = Equivalent flow
: at 1.5 in. Hg
: Example: for a 235 CFM 1-bbl carb
: 235 / 1.414 = 166 CFM four-barrel equivalent
: Hope this helps.
: CF
reptylkrib@aol.com
