It is currently Sat May 16, 2026 10:06 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
 Post subject: no power
PostPosted: Sun Sep 30, 2001 8:52 am
rebuilt a 79 225 for my 85 150 van installed a com cam rv cam super six carb intake planed the head 90 thou valve job new cop cam springs new time chain the carb and ignition cam off old motor worked fine did not deg cam have less power then old wore out stock motor 500000 not looking for a hotrod just though there should be more power not less motor runs fine just no power is this cam any good any advice would be appreciated thank you
brentmcl@home.com
 Post subject: Re: no power
PostPosted: Sun Sep 30, 2001 9:07 am
You really need to degree the cam. Many reports of timing chain and sprockets not marked correctly. I found one that was off by 11 degrees.
Charlie
: rebuilt a 79 225 for my 85 150 van installed a
: com cam rv cam super six carb intake planed
: the head 90 thou valve job new cop cam
: springs new time chain the carb and ignition
: cam off old motor worked fine did not deg
: cam have less power then old wore out stock
: motor 500000 not looking for a hotrod just
: though there should be more power not less
: motor runs fine just no power is this cam
: any good any advice would be appreciated
: thank you
flturbo6@aol.com
PostPosted: Sun Sep 30, 2001 8:21 pm
: You really need to degree the cam. Many reports
: of timing chain and sprockets not marked
: correctly. I found one that was off by 11
: degrees.
: Charlie
Boy howdy! My MP roller chain was off 15* to the retarded side.
aschumers@aol.com
