It is currently Wed May 27, 2026 2:34 am
 Post subject: wiper seals
PostPosted: Mon Jun 19, 2006 7:56 pm
Someone posted that leaky windshield wiper seals can play havoc with yout floor panels. I can verify that with a capital "V." But I seem to have lost track of where I can get them. Help?
PostPosted: Mon Jun 19, 2006 8:05 pm
Schumacher Creative Services, www.engine-swaps.com
PostPosted: Mon Jun 19, 2006 10:26 pm
Thanks
PostPosted: Tue Jun 20, 2006 10:09 am
Car Model: 1964 Dart GT
Dan, If there was such a thing as "Slant Six Jeopardy" I might have to put my money on you.
PostPosted: Tue Jun 20, 2006 10:19 am
Maybe in a past life I was a librarian.
Shhhhhhh! :lol:
PostPosted: Tue Jun 20, 2006 3:08 pm
Most of the time the wiper pivots are worn out. they actually can leak through them. I prefer to use umbrella type valve seals for a small block and some clear silicone to seal them. I have sone this to almost all of my A-bodies and i believe unless you are looking for a concours car this is the superior repair. Cheaper also.
________
Medical marijuana
________
MARIJUANA VAPORIZER
PostPosted: Tue Jun 20, 2006 4:12 pm
OH MY!! I really hate saving money and getting it right at the same time!! :wink:
Thanks
PostPosted: Tue Jun 20, 2006 4:18 pm
H'mmm. Not sure I'd necessarily call this "superior", for it leaves two seal areas completely unaddressed, with crunchy and dead seals remaining in place. I do like your valve stem seal idea, but would probably do it in addition to replacing the actual pivot seals with the repair kit, which costs all of $11.
PostPosted: Tue Jun 20, 2006 5:46 pm
I think you misunderstand. there are no old seals left in place. for a gasket where they bolt to the body you can just silicone them or use gasket material.
to each his own though.
________
Make a vaporizer
________
Ultimate Fighters
PostPosted: Tue Jun 20, 2006 6:18 pm
Car Model: 63 Dart 81 D150
not sure I understand, do the vlave sten seals go under the wiper arm outside the body? I have this problem on my 63 dart and was about to post the same question :D I also have some sb vlave seals laying around :D the shafts seem nice and tight, the wipers work real nice on their one factory speed :roll:
thanks a bunch, once I can get the floors dry I can start fixing them.
PostPosted: Tue Jun 20, 2006 6:23 pm
If you're not replacing the foam "doughnut" seals, there are old seals left in place.
No under the wiper you seal with silicone. You use the valve seals in place of the wiper pivot seals. Get some hot water and drop the seals in to make them very pliable. put some clear silicone on the splined part of the pivot and on the pivot body. slip the valve seals over the pivot. wipe off excess and let dry. I read this in a mopar mag years ago and unlike most of their"streetable "cam recommendations this really worked well.
Especially when you figure most gearheads already have spare valve seals and silicone. :)
________
Ferrari 248 f1 specifications
________
EXPATRIATE INSURANCE FORUMS
