It is currently Sat May 16, 2026 3:12 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
 Post subject: tranny options
PostPosted: Wed Oct 03, 2001 6:57 am
I am looking at buying a 84 1/2ton pickup with a slant six. It has a three speed auto. I am not familiar with mopar. Is there a OD auto tranny that will bolt onto the slant six? Thanks for any help.
garysgill@excite.com
 Post subject: Re: tranny options
PostPosted: Wed Oct 03, 2001 9:11 pm
I believe the 4-speed 833 transmission was an option. The automatic probably has a lock-up torque converter.
cfield@ll.net
 Post subject: Re: Truck tranny options
PostPosted: Wed Oct 03, 2001 10:00 pm
: I believe the 4-speed 833 transmission was an
: option. The automatic probably has a lock-up
: torque converter.
Yup, if you go to the trouble to swap to a manual, there is a "bolt-in" 833 OD 4-speed unit.
There are some newer Mopar 4-speed automatics with lock-up converters, This may fit under the cross- member of your truck but it does not fit a passinger car, unless you cut-out and re-inforce the cross member area.
PostPosted: Thu Oct 04, 2001 8:58 am
: Yup, if you go to the trouble to swap to a
: manual, there is a "bolt-in" 833
: OD 4-speed unit.
: There are some newer Mopar 4-speed automatics
: with lock-up converters, This may fit under
: the cross- member of your truck but it does
: not fit a passinger car, unless you cut-out
: and re-inforce the cross member area.
: DD
Note that you need a '60's truck adapter plate (slant six to SB mopar trans) in order to bolt the late model OD autos to your Slant.
madsenl@caltech.edu
