It is currently Thu Nov 26, 2026 6:25 am
 Post subject: Vacuum Hoses
PostPosted: Sun Jun 11, 2006 6:50 pm
I am planning the HEI swap on my '87,and while I'm doing that I want to replace the plastic vacuum lines with rubber hoses. I'm probably going to buy a whole roll of hose from the place I work at. My question is what size hose should I buy? Also would the vac. advance hose be the same size as everything else? (I forgot to grab it from the carb donor)
Nick
1987 Dodge D-100(225/904) Daily Driver
1979 Dodge Ramcharger (318/727/NP208)(Under Construction)
PostPosted: Wed Jun 21, 2006 5:41 pm
OK then,anyone have an idea how much I'd need for a '87?
Nick
PostPosted: Wed Jun 21, 2006 5:46 pm
I think you will need 3/16 and 1/8 diameter hose. I would buy about four feet of each.
PostPosted: Fri Jun 23, 2006 10:08 am
Are you sure I'll only need 4 feet,or is that just for the vac advance hose? I want to replace all the plastic garbage hose with rubber hose as well.
Nick
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 3 guests
