It is currently Wed Jun 03, 2026 4:01 pm
 Post subject: Imaginary post?
PostPosted: Wed Jun 21, 2006 7:15 pm
I could have sworn that just a couple nights ago I saw a post saying a Maverick hub would fit right onto a Valiant spindle, furnishing a 4.5" bolt circle. But a search on Maverick netted me nothing.
Was it here or did I see that some place else?
(I know about the posts regarding Maverick rear ends. That isn't what I'm talking about.)
PostPosted: Wed Jun 21, 2006 7:19 pm
The search engine is on the fritz.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Wed Jun 21, 2006 8:29 pm
The search engine isn't as broken as all that. It won't handle phrase searches, but it'll do word searches just fine, and there was never any such a post as RossKinder mentions on this site. RK, you either hallucinated it, or saw it elsewhere.
In either event, it's almost certainly not true.
PostPosted: Wed Jun 21, 2006 8:50 pm
There was a post that mentioned swapping a Maverick rear end into an A-body to get large bolt pattern at the rear. Perhaps that is the source of confusion.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Thu Jun 22, 2006 4:35 am
maverick hub--
I also have read the maverick hub story--
I think it was on all-par or the Houston club web site----
Have not tried it or looked into it further---
PostPosted: Thu Jun 22, 2006 5:59 am
As a matter of fact there are quite a few such posts over time, which is one reason I excluded them in my first query on this.
Thanks
PostPosted: Thu Jun 22, 2006 7:11 am
I don't know about Maverick hubs, but I have been told that some years of AMC hubs will fit and give the 4.5 bolt circle.
PostPosted: Thu Jun 22, 2006 7:38 am
Just curious. Why would one want to do this?
PostPosted: Thu Jun 22, 2006 8:55 am
To avoid having to swap to disc brakes to have the 4.5 bolt circle all the way around. On a daily driver one barrel slant six ten inch drums all around is plenty to stop the car. If someone upgrades to a later rear axle with the large bolt pattern it is much simpler just to swap the front drums to get the large bolt pattern up front.
PostPosted: Thu Jun 22, 2006 9:19 am
So we're talking spindle out or just backing plate and drum
PostPosted: Thu Jun 22, 2006 9:29 am
My understanding of whatever I read where ever I read it was that the Maverick hubs/drums had a 4.5 inch bolt pattern. That should mix well and easily with a Maverick rear end (if it were real-world).
Thanks
PostPosted: Thu Jun 22, 2006 9:45 am
My recollection of the AMC hub swap was that it is simply replacing the hub and maybe the shoes (different width?). No backing plate replacement. I have never worked on an AMC car so I can't say for sure.
